Reorder Radio sources 2014
thesavo
Albany
NY
2014 edge
I have attempted to research this but am coming up empty. Has anyone here tried changing the Order of the Radio inputs with forscan? I would like to move the BT audio a little higher in the list, as it is on the the second "page".
I think i may have to accept that the order is static and I should removed Unused inputs. Perhaps removing Sirius radio from the list would help.
I found this to remove Sirius, but have not had a chance to change it.
APIM 7D0-01-01 *xxx xxxx xxxx
Decrement existing value where the asterisk is by 2; if you have an "A" make it "8", if you have "2" make it "0"
url: https://www.fordedgeforum.com/topic/27415-removed-siriusxm-from-main-audio-display/
https://www.fordescape.org/threads/remove-sirius-from-mft-menu.84506/
T
thesavo
Albany
NY
2014 edge
I got the net effect I was looking for by removing Sirius from the lineup on the Touch screen,. I almost never use the right cluster screen. I still need to remove it from there. At least this looks better to me.
Sent from my SM-N975U using Tapatalk
