Radiator fan starts to work when i turn the key to the ignition position.
odlarhg
Hello, I have a Focus with Duratec 2.3 engine (PZEV) and I have a issue with the radiator fans. This are the facts: When I turn the key to the ignition position, the fan on the right side is activated (seeing the car from the front). If I activate the A/C the second fan does not activate.
Because the fan is always active, the motor does not reach the correct temperature for this reason I can not check if the second fan is activated when the temperature rises.
Any idea why this is happening and how to solve it?
(I hope you can understand me, I speak a little bit english)
