Perimeter alarm and forscan
Saford
Columbia
SC
Ford Edge 2011
Hi
I tried to disable the key fob panic alarm on my 2011 ford edge. I used forscan to change the BdyCm as built forma 726-20-01 0201 000A 5B into 726-20-01 0301 000A 5C. It worked but my car started honking twice and no flashing lights when I lock the doors. I figured out that the Perimeter alarm was automatically disabled, so whenever I enable the perimeter alam in the normal BdyCM I get new BdyCM as built format value like 726-20-01 0201 010A 5C that causes the car to honk twice and no flashing light. I loaded factory AB but got same issues
Any help how to get everything back, like active perimeter and one honk and lights when I lock the doors. They now never work together. Any help, please?
thesavo
Albany
NY
2014 edge
Hi. You may want to change the as built back to what it was and check if there is a non as built that does the trick.
2011? Do you have have a group 36 or 37? I think group 20 may be the wrong branch of the 726 tree.
726-36-01 xxxxxxx
I think your route is is for a later build f150.
https://www.fordedgeforum.com/topic/19350-keyremote-buttons-too-sensitive/
Here's the explorer sheet, since they are close.
https://www.icloud.com/numbers/0yl-Fqa3Gnjh8m0K-1vadEHiA#FORScan_Ford_Explorer_11-21MY
This thread talks about a diffent bit in 726-20-01
https://www.explorerforum.com/forums/threads/2011-2015-police-utility-forscan-settings.468943/
Sent from my SM-N975U using Tapatalk
Saford
Columbia
SC
Ford Edge 2011
Thanks I will give it a try
