High Beams always on
golfer guy
Renton
WA
2004 ford focus
I have an older Focus. When the lights are on they are in the high beam mode. Upon flipping the switch to turn the beams from high to low nothing happens. No click in the turn signal light switch and the lights stay on high. What would be the likely cause and fix?
Thanks
Stu-pot
Bishops stortford
Ford Focus Ghia MK1
I have the same problem, for me its the switch in the stalk, only a simple swap was needed.
If i were you I'd first check your fuses (fuses 26&27) under the bonnet. The the relay, if all that's good then ypu have my issue. Just buy a used one of ebay.
Sent from my SM-G975F using Tapatalk
