Clutch Master Cylinder Replacement – Wet Shoe Problem – How to fix it…
inventiv
Sydney
Australia
2002 Ford Focus Mk1
Hey guys, I got the dreaded wet shoe problem in my Mk1, so I checked the Clutch Master Cylinder above the steering column and sure enough the brake fluid war leaking out.
Here is a video showing the steps in case you need to do this job. Plan a whole day for it, and the help of a friend for bleeding the system afterwards – hope you like:
