Brake Caliper still siezed after parts cannon
Los Angeles
2012 Ford Fiesta
2014 fiesta 1.6 here from California. I bought this car with a single siezed brake caliper. (Front passenger caliper) when I cracked the bleeder screw it unsiezed itself. This led me to replace the brake hose and bleed all of the brakes. The problem still remains.
I then replaced the brake caliper. I removed the metal brake line and checked for blockage. There was no blockage. I reinstalled everything and bled the brakes. The problem still remains.
I tried swapping a used abs module without programming it to my car (module only) and the problem still remains plus I have the abs light flashing and traction light on. I can still swap reinstall it with my original abs module though.
Just to be clear. Only the front passenger brake caliper is siezed. But cracking the bleeder screw is the only way I can unsieze it. Any suggestions helps. Thank you
