- Messages
- 161
- Likes
- 107
- City
- interlachen
- State
- FL
- Country
- United States
- What I Drive
- 2011 fiesta se 5spd
Hope yall had Merry Christams !!
Hi there guys , i been wondering if any of yall had the stretch belt smoke for a min like it just sliding on top of the pulley, then is fine once you shut it off then back on
of course this wasn't just random , i was checking the new update on my scanner and decided to see that ford oem enhance was, with the engine on, tells you to turn wheel to the left ,
press and depress brake pedal and cycle override switch if equipped, while on the process the car will idle to 1500rpms , and stay there for few mins then comes back down to normal once complete .
In the mid of it , i get a stench smell like rubber burning , then i see smoke, shut the car off come around and see a straight line marked all the way around from the bottom cover ,parts
of the engine and ac hose , and i mean straight line like a stencil was used . i turned the car back on let idle for 5 mins and it was fine. I can only assume the high idle plus having the
steering fully to left put an additional load on the alternator ,since it does not have conventional P.S.Pump or the clutch on the a/c even tho it does not work but spins freely and i had
heat on medium on the vent side (left on the a/c control dial )rather than defrost , might have cause it to skip a rotation ( i know does not make much sense ,but who knows).
I will test drive the car tomorrow and see if anything happens , i moved it around the yard and parked it back and was fine , just wanna make sure since i need it for work Monday
the belt is but a year old and you can still read the numbers clear as day, and timing job was done 4 years ago or around 41k miles back, then of course crappy cold weather makes rubber shrink a little , definitely had a combination of factors for me to be fooling around doing tests that the car didn't need , i know lol " if is not broke don't fix it " XD
I had just finish doing same test on a 2010 Expedition and nothing smoked , however engine was at operation temp on that one , Fiesta not so much ..
Wondering on yalls input![Dunno [dunno] [dunno]](/images/smilies/icon_smile_dunno.gif)
