2.4 m/t bogs then eventually reves
North Branch
06 fusion 2.3l se m/t
06 Ford Fusion 2.4 L duratec SE manual transmission that I just picked up I had to put a clutch in it so I pulled the motor ended up doing a rear main seal a clutch and pressure plate now I have everything back together and the car will idle but if I pin the throttle it will bog and slowly gain rpm then at about 2000rpm + it will rev more normal as long as I stay above 2000 if I try to drive it I have to rev it to 3000 slowly let the clutch out and hold it at wot so it doesn't bog down and sometimes if rpms get to low if will just bog out then stall even if in neutral i have spent 2 days going through this and I'm stumped I have checked timing with the correct tools I have traced wires triple checked to make sure all connections are good I have looked at grounds also added with jumper cables to see if that helped and nothing car has a bad output speed sensor but was like that before and drove fine it has a code for that and a bad coolant sensor that's it any help would be appreciated
